You mean studs not lugs. The lugs are the nuts that hold the wheel on.
The rims are the factory 15’s
Kumho Mohave AT 10.5 R15 109
They were on the truck when I bought it @10 years ago. Another item to add to my list. I don’t think I’ve ever owned a set of tires for 10 years
Good info on torque rating, although arent the lugs supposed to to be tightened to like 88lbs? . I’m not sure why I couldn’t get the studs to seat. We were whacking the heck out of them.Press lug studs in or smack them from the back to seat.
7/16" studs are past their maximum torque rating at something like 75ft-lbs, I'd be willing to bet it takes a lot more than that to pull them flush.
The nuts are the nuts.You mean studs not lugs. The lugs are the nuts that hold the wheel on.
Sorry to get off in the weeds on technical terms. FWIW I've always called them wheel studs.The nuts are the nuts.
The studs are called lug studs. The nuts are called lug nuts.
If the studs come out with a tap of a hammer, then you get to replace your rotor hub assemblies. Raybestos is 140 each on Rock Auto and looks like the studs are already installed. If they aren't, then you just have to keep hitting it until it seats. It's either that or a press. It helps to have someone looking at the studs as you are hitting them in otherwise you start asking yourself if the stud is moving or not.Good info on torque rating, although arent the lugs supposed to to be tightened to like 88lbs? . I’m not sure why I couldn’t get the studs to seat. We were whacking the heck out of them.
What is weird is now the rotor is pretty fubar. The studs wallowed out the holes. I just tapped them with a hammer and they fell out. The holes are so big now that they won’t even stick.
Last I checked dorman had stopped making the 1/2" studs that were essentially the same design as the stock 7/16" for the front. Drilling was required.There have been some threads about upgrading the front studs to 1/2" or 14mm or something, but I can't remember if the knurl area gets enlarged or not. If your rotors are otherwise good, they might be candidates for this. I don't know how big you can go with the rally wheels.
