This thread is for the general discussion of the Item 85 K20, the little old ladys truck.. Please add to the discussion here.
Post the SPID and I will tell you what it came with.Been trying to determine what axle gears this truck has. Luckily this is the first squarebody I've ever had that still had its RPO sheet in the glove box.
GQ1 REAR AXLE-STANDARD
G80 LOCKING DIFFERENTIAL
Everything I've rear has said GQ1 would be a standard open diff with whatever gear would have been standard in whatever particular truck, but mine has a G80.
You could not get a TH350 in an '85 K20.
You have a TH400, so if that is stock, you have a C6P. A non C6P K20 would have had a TH700R4, and an LS9 350, as opposed to the LT9 350.
If your truck left the factory with a 350/TH400, then it had 4.10:1 gears.
Martin
In the ad she said it had a TH350, but when I crawled under and looked, I saw a TH400, I assume she just repeated what she had been told and that the TH400 is original.
Yep, 10th digit of VIN is F for 1985
Model # is CK20903, so a long bed, fleetside K20.
C6P - 8,600 GVW (heavy 3/4 ton)
LT9 - high torque 350
MX1 - automatic transmission, non overdrive
So your GQ1 is 4.10.
GQ1 just means no optional gear ratio was selected. It does not stand for a specific ratio, like GT4 (3.73) or GT5 (4.10). An '85 C6P K20 with a 350/TH400 had no optional ratios.
Martin
Sweet! I really appreciate that.
But I have another question, why would 8600# GVW truck have a semi float axle?
ALL 1982-1986 K20's have a semi float rear axle. Period.
Unfortunately.
Martin
Maybe get the intake pressure checked
9/16x18, 30* cone seat, and a 1" shank to sit down inside the wheel.
32Pc Chrome 9/16-18 Extended Thread ET Style Lug Nut Fit Ram 2500/3500 F250/F350 | Left | Lug Nut
Lug Nut Type: Extended Thread Bulge Acorn. Lug Nut Thread Pitch: 9/16-18. If Your Wheel Has Wheel Cap that Requires to Use Lug Nut to Hold, It May Not Work . Lug Nut Seat Type: Cone Seat. Lug Nut Hex Size: 3/4".www.ebay.com
would those work?
