Yes, but of course planning on lots more to be safe. What I meant is at this point, tentatively the axle location is looking good. At all axle positions, the panhard bar and bracket clears everything. The axle is closest to the panhard bracket at roughly ride height, and with the axle moved now I'm 99% sure the coilover has enough clearance to the panhard bracket at ride height. It gets further away as the axle goes up or down.
I have not fully cycled with a tire on (yet). I will need to trim the front of the fender to do that (hopefully moving the axle back helped a little, but it will definitely still need some).
That's a good point though, I should do that next before worrying too much about shock hoops because I need to make sure the coilover clears the tire. Other than the fender and the coilover, I can't think of anything the tire will potentially hit? I'll find out either way I guess.
Thanks for the help thinking through everything (you and everyone else)! It's very appreciated.
