This thread is for the general discussion of the item 85 k5 Red Furry. Please add to the discussion here.
Thanks for following and glad to see you doing a similar project as well. Im no body man either but the biggest tip is to take your time and double check doible check and double measure. Take your time and if you have to cut anything out then take small cuts. Its alot easier to recut and make the hole bigher, then to fill in a larger hole. So just don't rush it.Yeah, sorry, I'm also not sure about your belt solution, but I'm interested in your project. I'm starting on almost the same thing. 85 K5 but mine is already red but I'll probably change it LOL. After reading what you're going through, I just hope I can breathe life back into the GM Goodwrench 350 crate thats seems to have been in it for a long time. But my biggest concern is the body work. I've never done any, so this is gonna be an adventure. I wish I had the room that you do to work. I'm in my garage an a dog gone HOA neighborhood, so I'm restricted.
That's advice I will definitely be taking.Thanks for following and glad to see you doing a similar project as well. Im no body man either but the biggest tip is to take your time and double check doible check and double measure. Take your time and if you have to cut anything out then take small cuts. Its alot easier to recut and make the hole bigher, then to fill in a larger hole. So just don't rush it.
Thanks. They are a bit dirty right now but 10 time more comfortable. Found them on face book for 200 including the back seat but still need to make the bracket for the back seat. Sold the originals for 200. So only cost me material to make the brackets.Those seats are nice!
Yes im going to use the original serpentine brackets. I found a power steering pump that will work. The only thing now is to figure out the a/c compressor hook up.You can use the serpentine brackets.
You can use the EFI. '
Martin
