Hey everyone,
I recently replaced the camshaft on my K5, along with the timing gears and chain, the lifters, and valve springs. My plan was to leave the old valve springs for the break in (softer) and then once the break in was done, remove the heads and change the valve springs.
After putting everything back the first time, the truck started right away, and everything broke in correctly. Then I removed the heads to change the springs, and now they I've put everything back again, it won't fire up. It fires but not even for a second, and dies right away, it struggles. I've put the initial timing at 10 deg first, then 14 deg, but id didn't change anything. On top of that, there's smoke coming out of the carb everytime i start it.
Would the chain skip a tooth ?? even if it's new and the truck started correctly the first time ? is it the ignition timing ? I'm lost... need help :/
Thank you.
Thank you.
