Have a question. As I've been doing my rebuild for the last two years, I used my original HB from my donor 86' motor. It is the expensive HB with the rubber that often deteriorates. Mine appears to be all intact yet I can turn the outer pulley each way until it contacts the inner hub. There are basically stops cast into each that prevent much movement either way but it can move.
There are two things I've noticed that I believe are related to this and I would suspect that I need to purchase a new one. First is at idle the truck is rather noisy with a "clacking" sound. If I unplug the alternator it goes away pretty much and even when plugged in, if I accelerate the motor it goes away and the truck gets very quiet. The second is when I shut the engine off there is a slight metallic sound as it stops. Of course most diesels stop abruptly do to the compression and I believe this metallic noise is again coming from the HB as the pulleys want to continue to rotate when the motor stops and the HB rotates until the stops contact each other.
I also believe the "clacking" is the HB under the load of the alternator, pwr steering pump, and water pump. I think the sound is generated because of a slight on/off during the strokes at idle VS. the load on the belts. I might be wrong but I would think I still need to change this HB. Like I said, the rubber is in fine condition but the outer pulleys will spin on the rubber (could be the rubber spinning on the hub) and the "stops" will contact each other.
