I can get AllData schematics for you if you need them.
We got them Saturday. Full pinout and schematics. He’s going to finish it up at work today.I can get AllData schematics for you if you need them.
Man, so many stupid things going on it’s hard to explain it. Long story short, this wiring harness is from an Allison vehicle. The harness was pulled off the wrong vehicle. I’m so pissed.
My boss is looking for the correct harness right now.So the plan?
Doh! That sucks dude. You going to pair down the Allison circuits or shoot for another harness?Man, so many stupid things going on it’s hard to explain it. Long story short, this wiring harness is from an Allison vehicle. The harness was pulled off the wrong vehicle. I’m so pissed.
The only logical solution here is to swap an Allison in.Doh! That sucks dude. You going to pair down the Allison circuits or shoot for another harness?
Not to worry, all is not lost my engine and harness came from an 09 4500 with an Allison and I used WWW.LT1SWAP.COM wiring guild and changed to a 4L80 and have 0 issues.Man, so many stupid things going on it’s hard to explain it. Long story short, this wiring harness is from an Allison vehicle. The harness was pulled off the wrong vehicle. I’m so pissed.
I have zero money into the other one. I’m going to give the guy some money for LKQ pulling the wrong harness.If you already have a bunch of time and money into one that seems really stupid to me. But each his own I guess.
Lines are hooked up and pulley is on. Everything worked perfectly. On to the next stage!
Yeah this is all the lines from the square body stuff. Haven’t changed my lines since they were on the ported 2wd steering box.Questions about your high pressure line. Since the the pump is o-ring style is your steering box as well? Did you use a squarebody hose?
Wait wait wait wait, I totally messed up. Both ends of my lines are flare. I swapped to a new pump that worked with the 8.1 brackets, but also accepted the flare style. Go back a page or so and I posted the part number.Thanks for the info, I'm trying to find a solution for my flare box to o-ring pump.
I know that the fitting in the pump can be changed to the flare one in the TBI era stuff. I haven't tried it on anything past a '93 pump.Thanks for the info, I'm trying to find a solution for my flare box to o-ring pump.
Or you would have to do custom lines which could also ( possibly) use adapters. Like to go to AN fittings.
