The fan is clearly not a fan of your fan switch.![]()
I'm not a fan of that statement![]()
One 50? Lol
You should have a relay for each fan with a separate fuse feeding each relay.
I run one fan more often than two and I wanted redundancy. You're already running the wire so what's another relay and switch?
I'd like to be able to over ride the fans so when I go into a river it's not slinging it everywhere like last time.
Mine are switched from a bmw dual temp switch and I have overrides on my dash.
Wire in a buzzer so when it's switched off it buzzes
I usually don't run fans in the winter.
I usually don't run fans in the winter. Enough airflow from not having wheel wells keeps it around the 170* mark. I will be running them both on 1 90amp relay. What size fuse would you recommend? 40 amp?
And I never care about a high jack. I'm usually the high jackass lol.
