86 K20 projects
warwgn
NM
here is my new toy.
so here is what I got so far:
5 tires on the way
rear 6" lift springs (gonna take the fronts off the blazer)
got the wheels for 300 when I picked it up he took them off another truck, all I nedd it one more wheel for the spare.
now what it needs still:
6 shocks for a 6"lift (180 for es1000's pro comps off ebay)
new windsheild
new water pump, it's leaking from the weep hole.
fix the exhaust, it has glass packs and one pipe is broke right infront of the pass side glas pack.
set of plugs and wires and prolly a rebuild kit for the carb
basic tune up.
so might be a couple weeks before I start drivin it around, got to put the lift on and fix the water pump,and do the tune up. But to do the lift I got to find a set of tire to put on the blazer when I take the lift off so I can still drive it around. Dont think the 35's will fit when the lift is gone. Also does anyone know if I can put the 56" burb rear springs on the blazer? figure it will work and lift the back about 2"??
So when they put the temp tires and wheels on (33/12.5-16.5) they rubbed like a bitch on the runnin boards could barly turn. Needless to say I took those of right after the pics were taken. Had to move it out of the wifes parking spot before she gets home.
oh well here are the pics of it as it sat right when I got it home
Oh and it has a 8 lug SF14bolt, TH400 trans and NP208 T-case. Well thats about it for now, gonna strt workin on little stuff soon!
I am sittin here waitn on fedex to deliver my kit to fix the distributor
if I could just get it runn good. Got the distributor stuff done and it still has a bad stumble when I put my foot in it from a dead stop. Think I might need to lean it out some. But over all pudry happy for a 1k truck.
Could be the carb, but you might want to check for a vacuum leak somewhere before you go screwing around with the carb
hmmm didnt really think of that, a quick check seemd all was right but need to check real good to make sure.
also got to adjust the kick down switch, it dont work like it should. I know it works cause I can work it by hand driving down the road and it does drop down a gear, just the gas pedal dont actuate it.
I am at 6000' so not sure what to jet it at, I may have went too rich??
ok here are the pics of my electrical issue.Stilldidnt find the problem for sure but it works for now. I removed a lot of extra wire and the brake controller and the radio and speaker harness, didnt work anyway. So good news it works now, the dome lights, the bad news is I was sick as hell and just couldnt go out and work on it today to put it all together........ok my wife wouldnt let me until I get over this fever!
heater ducts laying in the back
and wala it works now!!
