tiny2085
Its an 86 K30 scottsdale chevy. drivetrain is 454/th400/np205. Motor idles good, but when you rev it up it "pops" through the carb. trans shifts great and t-case works well. 60 front and 14FF rear with 4.11 gears. All of the factory smog and emissions are still hooked up and shouldn't have any problem passing I/M. The a/c still works also. has manual doors and windows. The exhaust is dual magna flows. It has 6" TC front springs with extended shackles and a DIY shackle flip on the rear with factory springs and extended shackles. All new shocks, front has SS braided lines. The only bad part on the body is the drivers door. the drivers cab corner needs to be replaced. Located in Tooele UT. My cell is 435-830-9672 Caleb. I'm asking 3500 obo. If picked up before Easter I will throw in a tapped 2wd box and pass side high steer arm for free!!
