'86 K5 Isuzu 4BD1-T swap
shanker
Albany N.Y.
I've been meaning to start a thread here about my Isuzu Turbo-Diesel engine swap for a while. It's good to get input from the veterans.
I purchased the engine and accessories from a friend of a friend in Daytona Beach Fl. He was running the Isuzu motor in his C-30 Dually for a few years, but switched back to a BBC before the Gas prices went up. I bought the complete engine with a SUPER rare factory SAE #3 bellhousing mated to a chevy SM465 trans, and a complete set of chevy motor mounts that he had fabricated. I had just built up my 700R4 and wanted the overdrive, so I saved those manual trans parts & bought a diesel torque converter.
I'm running the Isuzudieselswapper aluminum adapter ring to mount the auto trans. They were very helpful, answering all my questions before I bought a kit.
I had to cut out the crossmember due to oil-pan clearance, and I'll be running a tubular Big block style X-member from ORD.
The blue hose by the alternator is an oil drain. The Isuzu Nippondenso alternators came with a vacuum pump on the back of the alternator, so I can run my power brakes etc. It has oil-fed bearings like the turbo, so it'll last forever.
I had a set of custom power steering hoses made to mate the chevy steering box fittings to the AN fittings on the power steering pump. The Isuzu diesels have a hydraulic pump built right in to the front of the block.It has a huge capacity reservoir tank and a lot of flow. I could run a hydraulic winch, or even a dump bed with that thing!
I tried cranking the engine with one Optima 1050cca redtop.. not even close to adequate. I'm running dual batteries to crank this thing. That's the factory setup anyway.
The motor's an oldie, manufacture date is 1980. It's actually a 4BD1 non-turbo. The engine block and head is identical to the newer 4BD1-T. The P.O. was a diesel tuner and bolted up a T25 turbo using some sort of kit. The N/A motors had slightly higher compression I think, and the T25 turbo is larger than a factory one so it should make good power. The injector pump has already been tuned for this setup. I want to add an intercooler but I'll wait & see how it runs out of the box.
I'm running a newer style alternator & a/c compressor bracket from an NPR truck.
Help
I recently bought a shut-off solenoid from a used parts place that I deal with regularly. It's designed for a later 80's model NPR truck. Do I have a different injector pump than the later models?
The solenoid has provisions for a shut-off cable and another cable that pulls the "enrichment" for initial startup. I can only find one lever on my injector pump, and i don't know which function it has!
What do you guys think?
the 14ft box trucks with these motors get mid-20's for mileage.
My K5 is actually more aerodynamic than the huge box & weighs a lot less. I'm running 3.08 axle gears and 35's so the gearing should be right in the sweet spot on the highway (1,700 RPM).
Probably 25-30 mpg. some claim more. The guy that sells the B/H adapters get 28 average in his fullsize pickup.
Here are the gauges I set up over the winter. I just finished plumbing and wiring everything up. I am now intimately familiar with the GM wiring diagrams!
It's a 3.9 liter 4-Cylinder. Rated at 105 HP and around 300 ft-lb stock. Mine has a much bigger turbo and a tewaked injector pump though :)
I'll probably be adding an intercooler once the truck has been running well for a few months.
These engines are in the 18ft Isuzu and chevy Box trucks (12k GVW).
UPDATE: The truck runs! I finished the rear disc brake swap and I'll be installing the radiator & plumbing etc.
Sweet! Glad to hear it's running now. I subscribed to this thread just to see how it comes out.
Here's a new pisture as of today. Radiator & shroud are in. I'm sorting out the 700R4 TV cable and the heater hoses.
My buddy works for penske and he gave me a pair of air-suspension seats from an international truck. I'm installing '90 suburban captain's chairs on these bases for a super-comfy setup! the air valves are fed by blue plastic air line Identical to the ones used for my ARB air locker compressor. :D Pics coming soon.
I chose the Isuzu over the 4bt because I found one first. I got a great deal on this setup and it was already in a chevy, so I had an easier time swapping it. The built-in power steering pump makes swapping easier and also the vacuum pump on the alt was a nice way to get power brakes. No need to hydroboost swap unless you want it.
The Isuzu motors are notable quieter and make a little more power than the cummins in stock form. Plus this one has been hot-rodded a little :D
I have a Pyrometer probe installed, but I was too broke to buy a matching auto-meter gauge when I did the dash. I'll be adding it before the truck is on the road (stupid I know, but I wanted to see the dash in so bad!)
Another plus is that I can buy parts for the motor at a chevy dealership because the isuzu box trucks were all re-badged as chevys too.
so how much would you say you have invested if you want to share?:D
i think its a great idea for a swap. just for those exact points you named.
I have about 3,000 invested in the swap so far. The engines are very expensive compared to gassers.
