notsosanestan
Registered Member
86 m1009 with 64k on it. Injection pump went and frame near steering box has the ord plate installed by previous owner and didn't do the best job as the holes for the box are a bitch to get to line up so I'm tired of it.
Truck has
Ord 4 inch shackle flip in rear
Tuff country 4 inch hd springs in front
Cucv m1008 1 Tons 4:56 gears
Rear has disc brakes conversion,u bolt flip kit from ord
Front has FUSH kit and hd front shackles
diy4x Dana 60 spring plates,ord crossover steering with
Hd tie rod.
It's sitting on hmmwv 37s with full size spare
Has the correct mil antenna on the side connected to a cb
I installed a tach and cd player.
900 watt 24 v inverter
Probably more I'm forgetting that I will add
Truck has
Hd tie rod.
