84CUCV
3/4 ton status
86 M1028 27k. all stock 6.2 60 with a LS 14bff with a locker. th400/208. has a new relay, drive shaft and glow plugs. runs and drive perfect. good clean running and driving k30. everything works the way it should. has good tires on it. as you can see the one door has a hit. has a older rear body. body is not in to good a shape. i was going to take that off and drop a bed on. didnt get to do it. can help with a bed too. $4000 questions call 732 966 6841
