86 updates
So its a manual latch?
Might find a way for it to latch when you close the door. Have a panel push teh latch as it closes.
na its easy, ive had latches like this on my last set of tube doors, real simple and smooth,
I like the idea of the rubber so the darn thing is not going to make noice or look a little cheesy like the gate latches or the slide up and over latches:tongue1:
I also like that when the body flexes, its not going to bind at the door bending the hinge and leaving it un-operable...Seen some do that.
i have arizona powder coating on washington do all of it,
I have been going there for for 6 years, nice people, fair prices. I also have used extreme powdercoating a month ago, as well as mesa podercoating and media blasting.
I would recomend them all.
he should have some pics up in the next few hours or tomorrow.. we worked on it all day pretty much but didnt make much progress due to a broken Pressure plate bolt (Dumb me forgot to turn 3/8 impact on low and its a IR titanium so it snapped one like butter, I normally use this impact on full for newer cars and trucks and have never broken one, maybe it was stronger because of the more air pressure at the shop were working at :eek1: ), anyways, the 465/205 is cleaned up and ready to be put in but due to a worn seal on the lift were using we couldnt move the truck.. :crazy: , should be able to kick some butt this week though.. Nate :D
:laugh:
the sm465 and 205 is now in...all clean and purdy:D
picking up shifters tonight... and changing a couple u-joints..and she will live again.
yeeee hawwwwwwwwwww!
supersize75k5 said:
:laugh:
Tire bite fender??
starting to get a tiny bit worried on my dead line..
only a few thing to do still... in two weeks..
front shock mounts..
rear shock mounts...done
rear brake lines....done
cut off and re weld spring perches..done
change diff fluids
pick up the tires.....done
find rims.................done
prep and herculiner interior..
paint interior...done
paint truck..
pick up the doors from powdercoating...done
finish rear bumper..add hitch
change u-joints in rear shaft...done
build front shaft..
drill holes for cage
swap on tbi
inline fuel pump
inline line brake
install dash..
front end pieces/lights/grill
get tags
and have exaust done
install powersteering pump and lines...done
swap tie rod
instrall dash parts
finish brackets rods for hydro clutch
mount tool box/amo can
build spare tire mount
build front bumper of some sort
install bew radiator
install water pump stud kit
install overflow bottle
install front recovery hooks
tighten pitman arm
put straps on rear d-shaft
make spare d-shafts..
fix rear wiring...
install mirror
install interior light
imstall minimum 2 rock lights
wire up bmw side lights
install tail lights
install head lights/buckets retainers/adjusters
find wheel wheel trim and modify
get line lock and install
restrainten/dye install dash
also moving in the next 20 days.. and working my job, plus helping out another persons customers since he is having heart surgery..:crazy:
who wants to start placing bets?:o
well juan blazer and mtnman? just got done droppin off my new tires.. 38 inch xmls! I am going to put them on some new hd wheels:laugh:
tonight..or this mornings project is rewelding on perches with a 6 degree change and ujoints and installing the rear before the sun comes up...
8 red bulls in the fridge..im on red bull # 1 right now:crazy:
yay.....motivation:thumb:
start at..2:27 am
3:50 am
14 bolt perches and 4 yes..4 shock mounts cut off.. perches reinstalled and welded..
also even shaved the 14 bolt since im so...um motivated
yay... rear axle is in! 6am
I i figured a way to install the 14 bolt while my truck is still stuck on a lift and 5 feet in the air...
what a work out!:eek1:
here is some pics
got the xmls.. well three of them mounted, also shows getting the blazer off the broken lift...
I picked up the polished hd wheels today..pretty nice
I am going to have to decide if I want to keep the tires and wheels though..cookie cutters:crazy:
and looky what I brought home for the buggy project..well I at least followed it home
whooooooo
