87 350 motor AC comp brackets, hose manifold, etc
azblazor
Arizona, Phoenix area
Want 87 350 motor - AC compressor brackets.
Also the hose manifold, i.e. the hose assembly that mounts to the back of the compressor and goes to the accumulator and to the evaporator. Basically all underhood hoses/fittings.
How soon do you need it? I have an 87 Burb that I will be parting out in a few weeks and will let all the AC stuff go pretty cheap.
I don't need the AC stuff immediatly. The 305 engine accesories should be the same as the 350 as far as I know.
The Suburban has different compressor (hence brackets) and hoses if it's a dual air setup.
I'm not sure whether or not it would work for you but I have pretty much all the a/c stuff in my 80 that's just sitting there you can have if you want it. The compressor is on the driver's side if that helps.
WOuld it be possible to get a picture of the brackets/AC compressor? If I drive down and take it I'll give you some money for it. PM me your phone number and I'll call you.
Thanks
