Sailor
Registered Member
Hello All,
So I've been having problems with my TBI when going downhill. When I am coasting downhill without touching the throttle, if I slow enough, it will stall, and if I clutch in to downshift it will stall. Only after the engine is warm (don't know temp as gauges don't work) will it idle properly at 650/700rpm. Overall, it feels a little sluggish so I'm thinking fuel pump or tps?
