budadavid
Newbie
Hello All -
I have a 87 Jimmy with a new GM crate motor, RV cam, starter, alternator, battery, ignition module, ignition coil, pick up coil, computer, throttle body, oil pump, distributor, cap, plugs, wires, EGR, air flow sensor: BUT - it wont run once it gets up to temp. It will start, run great (you can even drive it for a mile or two) and then it stutters, hesitates. You can then shut it off, and turn it back on and do that again for two miles.
I have been working with my mechanic on this for month and we are out of ideas - I will try anything before I take it to the Engine Dr. down the road at $95.00 / hr.
Please advise -
Please advise -
