ArchonBrutal
Registered Member
I intended to feed the 1008 running gear to the blazer and swap motor and Transmission for a ls3 and 4l80e. Now that both are in my driveway I'm having mixed feelings. I can fix the fuel issue in the 1008 and have an awesome work truck. And motor/Transmission swap the blazer on stock axles frame and make it more comfortable as a daily, that goes fast when I want it to.
With that idea in mind, am I setting myself up for breaking something on the blazer if I don't do anything with the axles and frame? Do you have a better recommendation on motor or transmission? I'm looking for power but still keeping "daily driver" in mind.
I'm looking for pointers on where to start with the fuel issue in the 1008. It starts fine but will die without throttling it a bit. It is a 6.2l diesel.
I cannot afford to shelf quality but I do have time, for now.
I can add info/pictures as needed when I figure out how to navigate this site better. Also, sorry if this is in the wrong place forums are not my strong suit.
