Looking nice. Keep it up!
I'm mean really.. Thats an understatement.. The high setting seriously cranks out some air.. Little noisy at that point too..
blazinzuk said:Thanks for the review on the heater. .
), & I love it!! I have a soft top jeep that I run around in all the time, & within minutes I have to turn in down. Remember, I live in the frozen tundra of Buffalo. I need to do a little better job of configuring it, because the defrost hose doesn't work like I want it to, but all in all, it's pretty flippin nice. Plus I don't have to worry about it crappin' out on me beacuse it's simple & robust. A little overkill, never killed anybody.
Wait, maybe I mis-spoke there, you know what I mean.My blower motor just went on me as well. I started looking for prices, and just got ticked off.![]()
I work for Goodyear part-time, so I can get some pretty good prices for parts. The cheapest I found the blower motor for was 135.00 at Autozone, and it was a special order part. By the way, it gets pretty cold here in Buffalo.The price of the blower motor made me start looking for other blower motor applications that would work in a TJ. Like the blazer one into a CJ or YJ. No dice. I just couldn't bring myself to "fixing" the o.e. terrible system just to have another thing go wrong in 3 mos, or 6 mos, or a year, or all three. The entire system is problematic. If it's not the resistor, it's the relay. If it's not the relay, it's the switch. Or the resistor caused the switch to go, and/or burned the wiring harness. Then it's probably the blower motor, if all of those things get fixed, blah, blah, blah.![]()
Not to even mention the issue you'll have if the heater core goes.![]()
My solution - tear out the entire heater system. Box, switch, motor, & all, & put in a heatercraft boat heater. I just got the heater box out last night, so now I'm going to figure out a way to get this little box up under the dash.
Let me tell you, there is a LOT of space behind the dash now. I'll probably try to figure out how to get more storage up under there.![]()
I'll have about 200.00 into the whole system by the time it's all said & done & have a heat/defrost system that is puts out 28000 btu's of warmth into my TJ.
That's about the same as I'd have spent on just the blower motor, (which was the last straw BTW), not to mention the resistor/switch/core/wiring that could have gone on me at anytime, & it's a much more robust, simple system which is about 1/3 the size of the factory system, and puts out 4X as much heat!!
(Just a sec, gotta catch my breath.
long sentence!)
Anyways, it's just a win-win situation for me. The disadvantage is that there is no selection to where you want the air to go. I'll set mine up to blow through the defroster & floor ducts if it's on. Fine by me, that's the only place I use it anyways. I am confident that this upgrade will crank out the heat, and I'll never have to mess with it again.
BTW you can get the heater & accessories from JCWhitney, or at any BoatUS. so parts for repair shouldn't be hard to get, should you need them.
I got mine from complete off road I got the idea from here. The internet & google are wonderful things!!
Later,
Buddy
BUDDY said:I installed the same type of heater in my TJ, (because if you didn't know the heaters in TJ's suck), & I love it!! I have a soft top jeep that I run around in all the time, & within minutes I have to turn in down. Remember, I live in the frozen tundra of Buffalo. I need to do a little better job of configuring it, because the defrost hose doesn't work like I want it to, but all in all, it's pretty flippin nice. Plus I don't have to worry about it crappin' out on me beacuse it's simple & robust. A little overkill, never killed anybody.
Anyways, HTH if anybody else is considering it. I would definitely recommend it.
Later,
Buddy
