Why do you need a new radiator?
cuz I'm going back to running the trans thru it... sucky thing, in addition to having to mod the shroud, which shouldn't be too bad, I just have enough on my plate already, is the manual, universal one I ran was like $150, the new one, slightly larger with auto provision is $300...
don't get me wrong, I'm all for killer trans cooling, thus why i ran "cooler only" before.. if i lived in the south, i'd probably do it... i will be running a huge earl's cooler on the new setup, so hopefully even with the rad heating the oil, the cooler will still get me down to that 175ish range in the summer..
hopefully if the next 2 days don't kill me, i'll be getting a bunch done this weekend... walked in tonight, looked in the dungeon and said "fock that" and came up to the AC....![]()
makes me miss my Mopars...
oh, I'm definitely not running "cooler only" again.... it's great here in Joysey in the summer, consistent 160 to 180, winter forget it..... when it's 15 out you can run the truck for an hr before it breaks 100... I'm pretty certain it aided immensely in the demise of my 700..
I'm doing a BTO unit, their warranty wants it thru the rad... considering I'm spending probably 2500 on the trans, I'll do what they want.. 300 is chump change compared to that..
throw in the fact, personally, I'm not crazy about bypass valves... it's great in theory, but it is a fail point, and potentially a huge FAIL at that...
it's not uncommon for me to come home and pass out for 2 or 3 hrs.... then I end up awake 1/2 the night on the comp...![]()
Well it's your rig so do whatever you feel makes you comfortable. I have been running cooler only for a while now, never had any problems with it. I haven't always had a stall converter either. What your tranny fluid milky at all? My guess is something else killed it but I guess we'll never know for sure, and operating temp definitely won't hurt it either.
And 2500? For what trans, 700R4? You could of had a 4L80E that withstands 750 hp for that amount. Although maybe not necessary for your plans.
At least your past the denial stage.
I used to do that for about a year several years back, I had to force myself to go do something when I got home, then I slept much better at night.
since I'm single again, I don't worry about my schedule... I have noone to answer to... I can come home and have cupcakes for dinner if I want...![]()
