Ok guy's looking for little help here. I have a 87 K5 with 350 TBI motor problem is when coming to stop after warming up it does a surge right as coming to full stop for split second then idles back up to normal. Does not ever set a check engine light. So what do you think it is? Little on my truck new after market dist complete,new msd cap,rotor,coil,wires,coolant sensor,knock sensor, throttle body from TBIparts.com with everything done even fuel pressure upgrade. This truck was bought from a friend that thought he knew alot and dang near messed with everything and rig all parts etc so chashing down and trying to fix problems. Thanks in advance Brandon
