Exterior was put together last summer of 2024 and I continued to work on putting the interior together which to date is still pieced together with random parts.
Learned a bit about hydraulics to build a 2-line wetkit. The company I run for we pull live floor self unloading trailers.
Wekit Included installing a PTO the transmission
The first pump I installed was too small and I had to purchase a new pump
Mount a used a hydraulic tank behind the sleeper.
Have hydraulic lines made for pressure and return side and install a pressure bypasd valve.
I was actually pleased how well it turned out. After about 6 months running it daily the hydraulics have worked great except I need to replace the old tank. It's formed a crack and drips slowly.
Most of the issues I've had running the truck daily this year have been minor. I've had to replace three of the rear inner axle hub seals.
The air powered clutch fan went out.
Replaced the air compressor
And this week I replaced the driver door. The original door formed cracks and since the mirror mounts to the outer shell of the door this ment my mirror kept vibrating worse every day.
Next project on the list is replacing the 36in sleeper with a 48in sleeper from a 2012 Peterbilt. This will get me a bit more space and I'm going to be adding air ride to the cab.
