Optima Bill
Registered Member
Well, I have found out the hard way that the two years are not interchangeable. I have the 89 engine harness on the 89 engine but it will not plug into the harness/fuse box at the dash connection point. So now I am at a crossroad. Do I swap the 87 harness onto the engine or do I swap the interior harness and fuse box? I am putting the 89 frontend on the 87, but if I retain the 87 wiring, no big of a deal to change that harness a bit for the proper connection changes at the lights. I am just wondering now if the 89 computer will work with the 87 harness. All the connect points on the motor are the same, but since they obviously changed the harnesses, not sure they all mate up on the computer right if I don't swap out to the 89 all the way through the truck.
Am I overthinking this? just swap the engine harness back to 87, make the small changes on the headlight harness and move on?
Thanks guys.
Thanks guys.
