88 cherokee clutch concentric bearing slave cylinder question
mofugly13
1 ton bucket of rust
San Francisco
Hi all. I'm replacing the clutch in an 88 Cherokee I picked up for pretty cheap. Its got an AX15 manual with an internal slave cylinder. The slave is supposed to be secured to the transmission housing with a little pin and retaining nut. The new clutch came with a new nut and pin, but no instructions on replacing the pin. The pin has a shoulder on one end. Does this pin need to be installed from the back of the front plate of the transmission?
Edit...Nevermind, figured it out.
