daylton
So after i take my truck out of 4x4
its still lunging forward like its in 4x4
any ideas how to fix this?
i only know 203 and 205...I think it's a np241 t case
The hubs being locked or unlocked shouldn't cause this type of issue unless the front diff is a spool or maybe a real aggressive limited slip.
To the OP, how far did you drive the truck after shifting back into 2wd? If you just stopped, shifted the t-case, and drove forward 5' with the wheels turned it might not immediately disengage if the drivetrain is in a bind.
Now low range can make it jerk forward and slam you with the tranny shifts. But just being in 4x4 feels almost the same as 2x4 except when you're turning. Is that what you're talking about - the jerking motion from trying to turn tightly on a hard surface in 4WD? You pretty much need both hubs locked AND the T-case engaged for this to happen. Unless you have a front locker - then you just need 1 hub engaged AND the T-case engaged OR both front hubs engaged.
