A few small updates, I am getting ready to go back down to Moab for full size invasion and I had a list of about 9 things on my list that I wanted to get done before I went, as it stands, I should have 6 of 9 things done before I get down there. The 3 that will not be finished are 1. new shocks 2. rear bumper 3. traction bars. The 6 that will be finished are: bump stops, sliders, heater core, CB install, trim fenders, and fix oil leaks (as there were many).
Along the way somewhere I thought it was a good idea to pull the dash for a reason that I forget, but while I have it out I am fiberglassing it to fix the cracks (in progress)
While I have the dash out I replaced the speakers. I honestly didn't know there were speakers there to begin with. I knew that was an option, but I never had the dash off to verify.
Next up on the (might as well) list was the cluster. It didn't look too bad, but it could definitely use a refresh. While apart, I destroyed my speedo when trying to remove the needle, bummer, but I found one on ebay (without the trip meter unfortunately) as I like to go back as "original" as I can for things that don't improve performance/aesthetics/comfort/ect. but lets be honest, the speedo doesn't work well with 40" tires and re-geared axels.
The cluster turned out better than I expected, maybe it has to do with the upgraded LED lights???
Big update here!!! I can finally weld something without asking a favor from a buddy. I tried at all costs to avoid doing anything that required welding because I would rather not ask for favors. Although, through the lifetime of this build I have had to ask for buddies to hook me up with welds on several occasions, and I greatly appreciate all the help I have had to get the blazer to where it is today, without the help it would be a very different, and far less capable rig.
Working on getting the cut lines perfect before I cut out the rockers for the
@the_blaze inspired rock sliders. Still need some tweaks before I cut. I did finally cut the rear fenders from the damage incurred at blazerbash.
Reference for the rear fenders...it happened on hells revenge at some point. Not exactly sure where??
