So I spent the day connecting all the coolant hosing and electrical. I also connected all the wires for my transmission controller which took an hour or so. I finished with putting the oil in the trans, transfer case, and engine. Then putting in the coolant. I intended on finally starting the engine but when I connected the battery the starter began spinning instantly. I thought I may have used the wrong wire on the ignition terminal on the starter solenoid so I pulled the wire out and connected the battery again--same result. It was really strange because nothing was connected to the starter except the positive lead coming strait from the battery. So next I connect the battery and looked at the starter while its spinning. The starter was spinning but the solenoid was not engaged, which it shouldn't be because nothing is connected to the ignition pole. I figure something has got to be wrong with the starter so I pull it. After its pulled its very obvious what the problem is.
If you look at the picture you can see that the connector I am using is bridging the input positive pole to the motors positive pole. Which isn't supposed to happen! I grabbed my hand grinder to shave it off so it wouldn't be a problem. This would bring me to my next topic--SAFETY.
I really wanted to get the engine started so I didn't grab my gloves or my face shield when I went to grind off the extra tab. While I was doing it some metal shards shot into my eye and I closed them. After that the grinder walked up the metal I was cutting and cut into my thumb. It could have been a lot worse so I'm lucky but damn, what the hell! WEAR GLOVES AND FACE SHIELDS PEOPLE!
After I got this gash to stop bleeding it started getting dark so I decided to call it a night. On a good note I will start Dory tomorrow for sure. Everything is ready. All I have to do is turn the key and bleed the fuel lines. So stay tune tomorrow to hear the beast!
I'll be moving to Juneau, AK. Looks a couple hours away from you.
Quick Link To View Juneau - http://maps.google.com/maps?f=q&sou...d=ijPUObZJoZDCHKtPb4u6xA&cbp=12,59.69,,0,7.26
Ouch... One of the reasons I stopped wearing contacts... glasses offer at least some protection against crap flying into eyes.
Juneau is a couple hours away from us by plane... At least a day or two if you drive.
