'88 K5 - Running Down A Dream
Ground up restoration of my '88 K5. The plan is to go through every inch of the truck and fix or replace pretty much everything that needs it. This will also be a full vert conversion and I plan to make the vehicle look more like a 73-75 than 88.
I think your pics just prove how bad the rust can get no matter what you do for maintenance on the exterior surfaces. Just about every piece of sheetmetal has an area that is unprotected hiding on the inside that allows rust to fester if water ever get in.
I agree 100%. Those windshield skins were bare metal in most places too. I was surprised by what I found in the windshield header and under the trucks drip rail. Definitely a good reminder to paint the backs of panels to at least slow it down.
I'm in spot welder prison right now. It's not as terrible as I thought, but I have all this other stuff not truck related I'm supposed to be doing so finding the time has been more challenging than I thought. Hopefully I'll get it knocked out soon. All I have left on the inner skin are the spot welds on the inside that are overhead and awkward. I've got them tacked but getting them finished is going to be terrible.
Inner skin is burned in, you'll notice clamps in the pictures. That's just to see if everything still fits. It does. I did get in my own head a little bit about whether or not I had everything set right front to back, but best I can tell from the bolts running the bed rail that hold the top down, you should have at least 3/8in of play front to back on the top. So surely it'll fit. I had about convinced myself the hard top wouldn't butt up to the two gaskets on the windshield frame, but it I measures out the same as my other windshield frame.
Got back at it after being on vacation last week. I spent a ton of time today measuring and remeasuring because I had about convinced my I mess up on the lower skin. I referenced five different locations off the rockers on each side and got identical measurements on passenger and driver side which was a big relief. I did learn that the middle piece that holds the two skins together. It's just hammered on there because it is not any kind of square. Finally got the end caps to fit and went ahead and painted them. So while the pain dried I started on the driver side bed rail. I need a break from the windshield frame anyways.
Precious little time in shop these past several days. Here's a compilation of the work I did to get the end caps on. Been sneaking away an hour or so here and there. Had to reuse a hole I cut with the spot welder on the RH side. Had to break out the sheet metal screws too. I only did more than tacks in areas people will see after assembly. These pieces don't do much structurally from what I can tell. These were not fun.
Got a few hours in today. Sprayed a little paint on the end caps so I can put the outer skin on next. While the paint dried I started working on the b pillar on the passenger side and learned something new, the front of the bed rails are wider than the rear. Never would have guessed. Can't really tell until you put pieces next to each other.
I'm in spot welder jail. It's terrible. I think there's probably 75. Maybe 80 spot welds on that outer skin. I've been working on it for basically 2 days. I think I'm down to like 20 spot welds. I think I was putting a little more work into welding those giant holes up than needed. A buddy of mine that does body work gave me some guidance. On the upshot, I convinced myself to go buy a mini belt sander. Should have bought one of those years ago. That thing is awesome. Currently, the plan is to fit the top Thursday. I am ridiculously nervous and anxious about it. Should have that outer skin finished tomorrow too so I can start working on the bed rails but I can fit the top whether those are done or not. Also, you'll see a burnt shirt in one of the pictures. It was underneath the truck on a box that had one of my bumpers in it. I started smelling smoke. I looked down and there was a flame underneath the truck. Molten metal went through the shifter hole. Fun times.
Hopefully that was a rag and you weren't wearing it at the time of ignition...
Fortunately, that was not the case. It was one of my good white undershirts, my best guess is that at some point I came down there with nice clothes on and took my shirt off and set it on that box and then forgot about it and went in the house. I'm just glad it didn't damage anything. There was probably a 12-in to 18-in flame by the time I got the shirt out from under the truck. It was right under the tcase crossmember but it doesn't look like it hurt the paint and it didn't catch the bumper box on fire which would have really sucked. I guess it also would have sucked if it burnt the shop down too LOL. I do have a fire extinguisher and it was within arm's reach.
As always, it took longer than I thought it would but I got it burned in. Tomorrow afternoon a couple people are going to help me put the top on. Other than chasing a few pinholes, it wasn't too bad today. I'm sure if I had done it the normal way and just welded it to the a-pillar I'd have been long done weeks ago, but oh well. Ironically too, my welding helmet light got delivered right as I finished.
Looking real good! :waytogo:
So, after freeing yourself from spot weld jail, what tips did you wish you knew before you started?
So, after freeing yourself from spot weld jail, what tips did you wish you know before you started?
The biggest thing is how to fill those old holes left by the spot weld cutter. They are so big, 3/8in, and sometimes there are two spot welds directly next to each other which we can leave an even bigger hole. Both the inner and outer skin and I think even the middle support skin are all 20 gauge metal. From working on that truck I have found 20 gauge to be way less forgiving and way more temperamental with your heat settings in comparison with 18 gauge. I've gotten pretty good at setting the welder, but for those giant holes you basically have to stitch in rosettes and use an air compressor, which I forgot to break out until halfway through. My OCD and lack of knowledge, I was wanting to fill them so that you couldn't see any cracks or pinholes left by the welding process (pictured), but the other side of me knew that that was putting way too much heat into those panels. My buddy that works at a professional body shop told me to quit filling them with so much weld because the filler would do that. I think having somebody that's done a true body work and paint looking over my shoulder would have been helpful. That's probably the biggest thing though. And I'll add too, once every spot weld is tacked in. You can put a little heat into that panel because it really can't move because it's got 75ish spot welds holding it in place. Heat management is important, but that does give you some wiggle room. If I had put that kind of heat in a bedside, it'd probably warped all over the place.
Another thing I'm glad that I did was keep a lot of those little discs left over by the spot weld cutter. Inevitably. If you go this route on a convertible conversion, I think you will drill some holes that weren't necessary. Some of those spot welds from the spot weld machine didn't really stick to anything, but you can't tell that until you've cut them out. Saving those discs is helpful for those holes where there's no backing to weld to. They came in real handy as hole fillers.
I haven't done that much of welding holes but worked with someone who did and taught me to be patient if I wanted it to be all metal and filler.
The first pass weld a few spots to attach the panels in each hole.
By the time you finish this the first hole is cooler and can take another pass of filling.
2 to 3 passes should be enough to fill them with a flapdisk in between passes to remove high spots.
I did most of my body work at his shop on the few vehicles I had and I got to work on them knowing he can my beginner mistakes
That's kind of been my MO for those holes like that. I'm generally pretty patient, but I started to wearing thin when I was doing all those on that windshield header. I think I counted 75 just on the upper. Those ones on that lip for the rubber seal were tough because they were vertical and the weld was harder to get up in there. It's just a weird spot. Also every time you grind them you would run the risk of getting them too thin. I had to build some back up because they were recessed and they were on a 90° angle on the bottom. Just a weird set up but I would take that over doing a long cut and then overhead welding it to the original inner skin that was on the my bazer. That's how my other friend did it and that would have been just as terrible if not, more so.
So today was wild. First thing I cleaned all the dust off that top, it hadn't been moved and probably 5 years. My buddy showed up, he's a big guy, like was going to be a D1 lineman till he got hurt. He looked me dead in the eyes and said I think we can both lift it up there. Somehow or another we got that top up there. My wrists are not what they used to be but we threw it up there and didn't tear anything up. We learned those little guide pins that blazers have on the back aren't used on those full tops. That was a fun little snag to figure out while juggling that giant thing. Also, while I was digging that top out of all the stuff and getting all the junk out from under it, I found a bunch of spots where termites were. The pest man showed up right as we got the top fitted and the Amazon man was right behind him LOL. Crazy day. Anyways, I do not think it is possible for the top to have fit anymore perfectly than it did. I measured it all over that windshield header and it was dead nuts. It was such a relief to fitted it and it had been that good. We took it off right before lunch and then I spent the rest of the day making a b pillar panel and cleaning a bunch of dirt out of the b pillar with a vacuum cleaner with a piece of heater hose I rigged up on the end of it. I'm hoping I can sneak into the shop tonight and start welding that piece in. You'll notice in one of the pictures rubber seals from PRP. Whoever made that seal that goes on the lip of the windshield header was either drunk or it was Friday after lunch because that thing is trash. I may jump ship and buy stuff for the top from Steel. Pretty disappointed since I had already bought every seal about 3 years ago and had them in a box ready to go.
I used to put the top on by myself but I didn't have a cage and it was on 31" tires.
It's not really too heavy to lift but it's bulky.
My 74 did have the locating pin, but my brother's 73 didn't
