THEMCGUIRE
This truck last ran about 6 years ago when it just died.
It will start and run while using starting fluid...
I do not see fuel coming from the injectors.
New stuff installed since then:
1. spark plugs and wires.
2. control module.
3. Fuel pump assembly. then just in case another new fuel pump
4. 2 new fuel filters
5. Fuel pump relay
6. battery
7. Starter
I have about 8.6 volts coming to the fuel pump from the front of the car to the connectors behind the driver rear wheel.
When I connect to the fuel assembly wires and check voltage at the fuel assembly it drops to 1.5 volts.
I am so confused. Help !!!!!
2. control module.
5. Fuel pump relay
6. battery
7. Starter
