THEMCGUIRE
Having trouble with understanding the wiring diagram. But to me the diagram looks like the output from "E" at the relay runs directly back to the fuel pump.
So my plan to splice E after it exits the relay and splice it to the pump seems ok to do?
or does it go to the oil pressure switch FIRST. It is really tight where the oil switch is (that is new as well btw). Do you think that the "E" wire goes to the oil pressure switch or not ?
I would not want to bypass that switch on an engine that has not run for over 5 years.
