I have an 88 TBI 5.7L Blazer that smells like it's running very rich and is only getting 11 MPG. Is that normal for TBI? i thought they got better then that.
new fuel pressure regulator
Coolant temp sensor works properly
no check engine light and no codes found
has 93 suburban engine recently installed by me but original TBI unit and had same problem with old motor, i only replaced it because the block had a freeze crack
mechanic doesn't even know what the problem is
Any suggestions?
Any suggestions?
