88 u joint problem need help please
kidn1980
THE BIG STATE
I need to replace my rear ds ujoint axle. I went to the local autoparts stores and they have given me the wrong one. The one I took out was a spicer brand and can't find a cross reference number. Basically what I have done is taken 2 different u joints to make one, ok on the outside clips fit fine but the inside clips are about 1/4 inch off on each side. I need to find correct one. To my knowledge I have stock parts. 10bolt
Oh. Drive shaft. I was thinking driver's side for a minute and very confused.
Measure your old one and take note of where the clips are located. It is possible someone swapped drive shafts at some point and put a conversion joint in there.
If it has internal clips and a steel shaft it should be a normal 3r/S44 u joint. 1.125" caps and 3.625" wide. The moog number is 534G.
What did they give you for a u joint that didn't work? External clips it will be a 13 series joint. It dies into the driveshaft right but is to short on the pinion? Sounds like a 1330 yoke and 1310 driveshaft same cap sizes but the 1330 is longer.
Yes it fits the driveshaft but to short on yoke. So what do I do from there or can you explain a lil better for me please. What size of joint do I need? How could you tell what kind of ds I have or yoke?
Measure everything and look at the link above.
I'd guess 1310 and 1330
Now 1310 & 1330 I am assuming that's the joint and if so what brand and could I get it at local autozone. Thanks for the help:doah:
Calipers would be best, but if it's darn close to 3 5/8" I'd say that's it
I've been abusing that exact Brute Force 1-0134 U joint in the front shaft of my 92 and ford D60. Spinning 38" boggers in the mud.
Thanks dueling I ordered it, installed it so we will see how long if last but really appreciate it everything lined up good.
Awesome! Now you must buy the membership here. It is the right thing to do after you are assisted.
EVERYBODY GETS 1 :whistle: :haha:
