superwrench
I have used several sets of the 882 heads on different motors that I have built and had no problems. You build the heads acording to how your going to use them. As for the vortecs, we have a stock set of them with 555 lift using stock diameter springs, turning 7000 rpm nightly. We have had no problem with them. The reason being is we used springs retainers that increased the installed hiegth and these have stock guides. We have one set that we left the stock intake size valves in them 1.94 and put in bigger exhaust valves 1.6... with bronz guides they work great.. What works for one person might not work for another, do your home work. Call your cam rep and tell them what your doing, they may have so suggestions for you about springs and retainers. There are hundreds of options.
....so my summary is this:
