89-91 Pinstripe Tape
Shawn
Nuckin Futz!
Author
5280'
Anyone know where I can get this pinstripe tape for 89-91? Nothing found on LMC. Found the triple pinstripe tape for the 88 and older models but nothing for 89+.
I think I found some that matches. Or at least close enough... Wanted to update this in case anyone else is looking down the road.
I bought similar many years ago and hopefully have enough to go around again for next paint. The local paint supply couldn't get it, but I found it on Amazon.
I’m going the custom route for the older style 5 band, but amazon has a pretty wide array of pinstripes. With the way thats laid out (all straight lines with no bends) that should be pretty easy to source, even if not OE specs. My issue was covering up a painted pinstripe with the 90* on the fender, that was the killer. The repo pinstripe kits that are available werent going to work for what I needed.
Problem is i have a painted on pinstripe that doesnt taper like the factory pinstripe on the vertical on the front fenders. I had the pinstripe custom made so that it will cover the existing pinstripe completely. Unfortunately they messed a couple sections up and are remaking them. Look to be high quality so I’ll be really happy once I get it on.
