There sure is a lot to know about mounting a plow. The first thing I learned is that it does not work with cross over as the plow frame would now be in the same plane as the pitman arm operates. Thia means that mounting it on the Trazer would require going back to the old push/pull set up. The second thing I learned is that there are a lot of different variations on how to mount a plow. 1987, 1988, and 1989-91 are all different. So, I was going to just put the 1991 serpentine set up on the 1987 (and still may) like Martin suggested. But it looks like I should invest in a new water pump rather than put the old crusty one from the 1991 on the 1987. And that is about the same price (or close enough) as the hydraulic bracket kit that SweetK30 suggested costs. The bracket would also be the easiest solution. The catch is finding one. I am looking for the brackets and have a few people that are looking to see what they have. So, if there is a bracket kit out there, that will be plan A. If not, it will be converting the 1987 to a serpentine set up. So glad you guys mentioned the ideas. The only other idea I had was putting a new transmission (among other things) in the 1991 and trying to run that. Uggghhh, so much fun.
