Not off roading, boating. My dad buys smokes at the casino
its your typical hard dirt and soft sand desert with lots of hills etc can go deep into some cyns and let the wife fire off a few 100 rounds with the .45 and AR15Not off roading, boating. My dad buys smokes at the casino
That is definitely possible the skyjacker soft ride five leaf spring pack seems to ride much better than the tough country easy ride, three leaf spring packNo, the springs just may have a spring rate that causes it to buck.
Ok they definitely are working that was an interesting drive thanksThe driver's side shock has a small shadow of oil at the bottom of the body, maybe it's dead?
What about just disconnecting the rear shocks from the axle and drive it, if the shocks are good then there should be a noticeable difference without them.
Thanks for pointing that out.I have a question on the rear, the shock available up stroke looks shorter than the distances between the bump stops. have to also consider the bump stop compression.
Are those the normal rear shocks pictured ?
Instead of turning left in CA go a few move miles and turn left in AZ stop by for a visit, ammo is easier to get here, and we have desert to shoot in, or I am a member of the range here.
I was just about to mention that. It looks like the shocks are bottoming out - notice how clean and shiny the shaft is on its entire length.I have a question on the rear, the shock available up stroke looks shorter than the distances between the bump stops. have to also consider the bump stop compression.
