And go to the link so you have the factory service manual troubleshooting flow charts, so you can understand what sets the codes, and how the components operate.
those tests with the ignition switch on?
ignition on, engine stopped
Dam, you start with good stuff!alrighty then, got me an actron cp7677 auto troubleshooter multimeter, loaded for bear now.. soon as i figure out how to use it, i will get those test done lol. I assume I am performing those tests with the ignition switch on?
no throttle sticking, idle screw not been touched to my knowledge, blades look fine, the TPS unit itself is new just replaced by a local gm dealer within the last 2 weeks, is there a solenoid somewhere I am missing?Yes technically it should be .54 volts, but realistically if it is under 1.12 volts it is fine... I know people will argue this but that is the way the code is...
Why is it so high? Is your throttle sticking? Have you turned the little idle screw in? If you pull throttle closed will it go down? If you have worn blades or sticky throttle and it closes more after you start the truck it will set a TPS code. This is because the ECM reads the TPS voltage when it starts and sets a "0 Percent" if it changes to -1 percent then a code sets...
Biggest point of a TPS code is a glitch in voltage! Read it again and open SLOWWWWWLY and watch for smooth rise, if you see a glitch it's bad.
Well tell them to fix the dam thing?the TPS unit itself is new just replaced by a local gm dealer within the last 2 weeks,
