'Cause you know more than I do on how that code would be triggered!
Code:
; error 22 param's
; Low TPS
LD523 FCB 10 ; TPS limit, 0.20 VCD
LD524 FCB 48 ; DEFAULT TPS, 0.96 VDC
I was also wrong in this thread or another where I said it did not matter what TPS voltage was if it were below 1.xx... it is 0.96 as shown above.
Grounds and welding could be an issue!just a fluke, unless the grounds were disturbed somehow. Any welding?
Have you taken a look at the grounds on the motor? I have seen some that the wire itself was broken down a half inch from the eye.
