mudbog42
Hey all,
I was wondering if I could put my 350 out of my 86 K-5 into my 89 K-5.
Reason being is the 89 motor is getting worn out and the 350 in my 86 only has about 15k miles on it and I will be doing a 5.3l or 6.0l conversion on it soon
, so I wanted to donate my 350 to my wifes 89.
I just wanted to know if that would work?
I seen that trans dapt has an adapter to put the throttle bodies onto my carbed intake manifold. And of course I would need a block off plate for the mechanical fuel pump.
I'm sure there is a little more to it than that, which is what I wanted to ask you guys. What else would be needed?
Thanks,
Mudbog42
I seen that trans dapt has an adapter to put the throttle bodies onto my carbed intake manifold. And of course I would need a block off plate for the mechanical fuel pump.I'm sure there is a little more to it than that, which is what I wanted to ask you guys. What else would be needed?
Thanks,
Mudbog42
currently has an "RV" cam
