omgwtf2
Registered Member
Hello to all.
I have a 89 K5 Blazer 350 TBI Code K 98k miles Auto 4x4.
Things I replaced: Heads/Coil/Distributor/Cap/Rotor/Wires/Plugs/Radiator/Thermostat 195F/Exhaust(full length Headers)/Upgraded FPR adjustable with Vacuum/Rebuilt TBI/Timing chain & gears/o2 Sensor/EGR & Solenoid. All stock replacement MSD (Cap rotor coil) & AutoZone.
Timing is set at 0* (with wire unplugged)
Reset by disconnecting battery for 5min.
1: Drive for 10-15 minutes SES light comes on. After 45 -1hr it shuts off and it just repeats.(During errands) Jumper/Code 32 appears.(Engine runs smooth all speeds & idle)
2: During normal driving I have no visable exhaust, if I try to pass (3/4 throttle) Black smoke comes out. My new dual exhaust pipes are getting sutty.(650 miles)
My fuel pressure (inline connector in front of filter) With no engine just ignition is 6psi. With the engine running 14psi. The adjustment screw is all the way backed out on the FPR.
I have a MSD 6al box mounted not hooked up yet. I wanted to see my gas milage before & after hook up. I'm getting 13.4 with these problems.
Thank you all in advance for your time & help.
