I did more prep work for the 4l80e + Magnum install.
Installed the TPS jumper wire.
https://www.summitracing.com/parts/cei-108103
I only need the blue sender wire so I capped the white and black wires. I also did my first solder job in the truck. It was a pain holding the wires in place but I got it done. You can see the end results there on the green wire above.
So funny story related to installing the TPS jumper. I needed to verify the wires and it was my first chance to use my new multimeter. I've had one for probably 10 years that I keep in the truck, but if I needed one when the truck wasn't handy I didn't have one. So I bought a new one that is autoranging and all that fancy stuff.
I couldn't get the damn thing to work right. I was thinking the auto-ranging thing was a waste of time. Then after doing to internet searching I realized I was being a dummy. This is how the leads look coming out of the box.
I thought they were fancy new fangled leads that no longer used bare metal ends. Figured it was one of those upgrades that came along with the auto-ranging feature. Nope, those are just caps.
Once I took the caps off the multimeter worked great.
I also routed the wiring harness for the transmission through the floor. I have a cover over the hole from the standard transmission shifter the truck came with. I used a hammer and round rod to make a tunnel in the cover that the wires fit in. Only got a picture of the carpet pulled back before getting the harness routed. You can barely make out the front edge of the cover in the picture below.
The wiring you see there is for the stereo mounted in the console, amp behind the back seats, and ARB compressor that's in the bed.
So back some time ago, I had posted this:
I'm also finding further frustration with getting the 4l80e controller setup.
Apparently Holley recommends against tapping into the TPS signal to run another controller like for the transmission. Done some searching and not having any luck finding if people have been trying it and if it's working. It's hard to believe there aren't a lot of Snipers running in vehicles with 4l60e. Maybe that means it's not an issue and Holley is just giving themselves an out, aka CYA.
So if I can't tap into the sensor wiring, I'll have to get a second add-on TPS. Ugh!
Well it turns out it's not just a CYA. On the drive home the Sniper would not stay in closed loop. Considering the only thing I changed was adding the jumper in the TPS, I'm pretty sure that's the cause. Some quick Google searching brought up some results with people having the same issue. Apparently any variation the TPS signal will keep the Sniper out of closed loop. Soooo, now I need to get an add-on TPS.
Just curiosity sake, I did a similar search for FiTech and it doesn't seem to be a problem to use the jumper on their EFI. So that's something for people to consider when deciding between Sniper and FiTech.
When I drive the truck back to the shop for the 4l80e install I will unplug the jumper and verify that's the cause.
