It was discussed, but there's not much holding the cowl panel.
I have found a decent variety of spacers at the local True Value.I was going to use spacers like factory used, but they are surprising hard to find. At least new anyway. Plus I'm using larger 1/2" bolts.
I also went with fine threads this time around.
my hot tar machines use these and all the rolling on blacktop on steel wheels and over cracks and every thing they work .One of the other maintenance items I had was to replace a missing bolt in the transmission crossmember. The nut and washer were sitting on the frame rail like the bolt was still there. I figure that means the bolt vibrated loose. That surprises me because I used the all metal pinch lock nuts. However this isn't the first time I've found loose or missing bolts in this crossmember.
I decided to try Nord-Locks this time. Supposedly they're better against vibration than other types of bolt locking.
the spacer was used to give the correct clamp load on the longer bolt to get the spec they needed .I was going to use spacers like factory used, but they are surprising hard to find. At least new anyway. Plus I'm using larger 1/2" bolts.
You confirm my thinking with going to the fine thread.I just use the all metal pinch lock nuts. If they loosen, it likely just crushed the paint, and you retorque once and done.
If you get one that consistently won't stay tight with those nuts on it, its likely the clamp load isn't enough and it's still cycling the fastener. You may need a finer thread and/or stronger (higher grade and/or larger diameter) bolt torqued to a higher preload.
This was the first time I'd ever heard of the Nord-locks. Thought it would be worth trying them out.my hot tar machines use these and all the rolling on blacktop on steel wheels and over cracks and every thing they work .
