I agree with Chris
Thanks, I'm glad it's helping you out.Subscribed! Great work and sweet build. I'm going to steal some of your ideas, like the template for the shackle mount. I'm about to start the same swap on my 1991 R3500. I have a question, you might have said already but i didn't see it. What front shackle angle are you going for and about how long are you expecting your shackle to be? I'm kinda up in the air but i dont have the adjustability that you do, I'm using the factory front spring hangers. And last, how much drop is your pitman arm? Sorry for all the questions, thanks!![]()
I'll let you know if that template works out with the frame clearance on the rear bushing, that's my only concern at this point. It did work for getting the spacing right between the front hanger and frame hanger.
As for the shackle angle, I want to make sure the springs are setup to function properly since Stephen went to all the trouble to design them. I spoke with him and he said to use the factory spacing which yielded approximately 90 degrees on the shackle angle. I don't know if this is best for all springs, but shackle angle does have an affect on effective spring rate.
I've been running this pitman arm for 7yrs so I don't remember the drop; it came with a crossover kit. I can measure it to figure it out. I have recently measured the length and it's 6.5" center of hole to center of hole.
You cant just move the springs back a hole in the mounts? Or you just trying to avoid that?
Yeah, I'm much happier with the location of the tire in the wheel opening as well.That looks much better.
:Thanks. Not going as fast I'd like.Looks good man! You're really knocking this out
I've got Blazer Bash looming in what seems like just a few short months already. I want to have some trail time in before heading out to Moab.Thank you. I'm always taking note of the older fullsize lifted trucks I see around town. Not a lot of the older iron; mostly new lifted diesel trucks. Funny thing is with a truck this size I'll have plenty of opportunities for gas station discussions.Great job man. Good to have a boost of motivation. Its well worth it when you roll down the road. First time I did the swap on my CC I went to get gas and a young kid was checking it out and loved it, Said he was working on a 79. Cool to bs with other fullsize guys
ScottI have the hyrdoboost that came factory in my K5 because it was a diesel. The CC has hydroboost as well. I'm going to use the hydroboost from the K5 because it has the Vanco hi-flow treatment done to it. Can I use the master cylinder that's in the CC with the K5's hyrdoboost? Or does the master cylinder need to swap also?
I prefer the master cylinder in the CC because it's the plastic/aluminum style so it's easier to see the level and I just think they look more modern. Just not sure if it will work with the K5 version hydroboost.
FWIW, the K5 is an '84.
