Any more pics than that?
I always enjoy seeing that big crew cab on the trail
I would think vent is pluggedTook a trip to the Black Hills for the past 4 days. Pulled the camper with the crew cab. Had a bit of trouble on the drive up. Stopped for gas about 2.5hrs into the drive and noticed fluid spots on the camper like I've seen when I had leaks in the past. I noticed fluid puddling under the truck. Found out it was coming from the transfer case output.
We parked the truck, ate lunch, and picked up a new output seal. When we got back to the truck the fluid wasn't leaking out the seal anymore. Level in the case was still good. We decided to try it out for a little while and see if it would hold. So glad I installed the sight tubes so it's easy to check the level.
Taking a walk down memory lane, back on the first trip I made with the Magnum box, I had the output seal blow out. I had suspected at the time it was related to speed and/or bad output bearing as I had been driving 75mph at the time it happened.
With that in mind, before I discovered the leak I had been running just under 70mph - that's been my self-imposed speed limit since the seal blowout. I was thinking maybe I was going too fast with the load. I decided to start out driving at 55mph. Checked this out after about 10 minutes and it all looked good. Drove another hour at 55 with no leak coming back. Finished the drive to Custer running 60mph. Never did have another leak. On the drive home I started out doing 60mph and after no leak half way thru the trip I kicked it up to 65 and didn't have any trouble.
My theory is there was too much fluid in the NP205. Taking a walk down memory lane again, when I first installed the Magnum I had a bad vibration that I tried to cure by adding more fluid. Turned out the problem was drive line angle. I lost some fluid when I blew the seal out but I don't remember if I added some back in. I think I might have put a half quart back in the case.
Right now the level is about where it is in the picture above. I'm going to leave alone and see what happens.
What I don't understand is why it didn't push out the vent. It seems like both instances it has blown out the output seal, one time blowing the seal out entirely and the other time pushing past the seal. Probably been 3000 miles between incidences. I think I need to check the vent line to make sure it's not plugged somehow.
I have wondered the same about my 241 if it can't handle the 85MPH or I just suck at resealing the case.I wondered about vent size too. I was thinking when they built the NP205 speed limits were 55mph and people weren't running their trucks at 70mph towing a 4000lbs camper.
I'm hoping it was just finding it's own level. I'll run it a while and start testing higher speeds to see if I get a leak out again. If it stays happy at this level, I'll mark the tube so I know where it needs to be.
I know for a fact I overfilled it when I originally put the NP205 in. I think it might have finally gotten rid of all the excess fluid on this past trip. See, overkill can be a bad thing!I never had a problem running 85 mph with the 241, and didn't have a problem with 75 mph with either one of the 205s. But they weren't clocked, so I am betting that yours is overfilled and churning the oil too much.
The rear axle under the old '72 K5 would blow oil out of the vent after running 70 for too long. It's pointed up for the CV shaft, and I believe that it's overfilled and foaming the oil.
So I wonder if you should pull a few ounces out from where it's at, then take it for a drive.![]()
I'm actually running Amsoil ATF. I've become one of those Amsoil geeks over the past couple of years. Mainly because I started using the Z-rod motor oil with the added zinc, but I've switched to their ATF and gear oil too.Just drain the atf then refill with straight Lucas and boom, no more leaks!
I have the NV263XHD in the Silverado. They actually recommend switching to a good synthetic 5w30 (from ATF) and adding an extra quart. The oil doesn't foam as much as the ATF so it runs better with the additional oil.
I've only recently switched (had to replace the output slip yoke bushing) but it seems good so far. Unfortunately I can't go more than ~73 or I hit a harmonic on my 65 foot long driveshaft and it shakes so bad it walks the slip yoke bushing out (which is why it got destroyed).
If you still end up throwing ATF out, try switching to 5w30.
Is the Silverado driveshaft 1 piece?TBH, your brother's is longer... That's why he has to run an aluminum shaft.
But to answer your question, the driveshaft is way longer than the S-10 links.
