Still not 100% sold on the mechanical fan for the trail. As long as we used gearing that keep the engine RPM above 1500, it was fine. As soon as we'd stop, it was start heating up. If I knew we were going to be stopped long enough, I'd just have him shut the truck off. The two trails we're difficult but there was a lot of steep climbing so it was just always under a load.
I know it's hot when I start bursting air lines. I have most of the plastic stuff removed, but there is a length from the solenoid manifold in the engine bay that feeds a gauge in the dash. It burst up along the fire wall.
Nothing was out of line hot, but it was always hovering around 200F coolant temps. And because the motor is running hotter, the trans does too. I really missed the electric fans when I could just stop for a bit and they would cool things down.
I know I'm going to get some push back on this, but right now I'm planning to put a pusher fan on the front of the radiator. I decided this after researching fan clutches and seeing that they would put electric pusher fans on 454's in RVs. I'm going to put a fan on the driver side where all the extra diesel radiator is. My hope is adding this will help the truck cool down instead of heating up when we're stopped.
My truck does the same thing in Moab, with the heavy duty fan clutch I can roll 10 feet and have it drop 10 degrees... Eventually I want to swap to the Tejas electric fan setup.
just asking..
