I have two different sets of 2" wheel spacers for 8 lug axles with the 8x6.5 bolt pattern found on all the old 3/4 and 1 ton Chevy, Ford, and Dodge trucks/SUVs. I took these on trade for some long travel shocks and already have a pair in use on my project truck so these are looking for new owners.
One set is 8" diameter with a 5" center bore hole and 1.25" of stud sticking out past the face of the wheel mounting surface. It has tighter holes for the axle wheel studs and is designed for 3/4 hex bulge nuts in the countersunk holes. This set comes with brand new 9/16-18 3/4 hex bulge nuts for the axle attachment and used 3/4 hex bulge nuts for the wheel attachment. In total you are getting 32 lug nuts making this a complete bolt and go setup if you don't already have any lug nuts or yours are needing replacing. This set would be ideal for steel rims with standard thickness wheel centers but may also work with some aftermarket alloy wheels with medium thickness wheel centers.
The second set is 8.5" diameter with a 4.75" center bore hole and 1.75" of stud sticking out past the face of the wheel mounting surface. It has larger holes for the axle wheel studs and will take full 7/8 hex lug nuts in the countersunk holes. This set comes with brand new 9/16-18 3/4 hex bulge nuts for the axle or wheel attachment depending on preference and what style lug nuts you already have. This means you will have to use 16 of your own lug nuts to make this a bolt and go setup. This set would be better than the other one if you are running aluminum or aftermarket wheels with thicker wheel centers but obviously they will work with regular steel wheels too.
I will take $50 cash firm per set picked up, with the first buyer getting their choice of the two sets if they don't want both.
Located in Spring Hill, TN 37174
Thanks,
Jesse
610 999 1546
Thanks,
Jesse
610 999 1546
