9.5 sf in blazer e-brake cables?
bablazer73
Starr South Carolina
I am thinking of swapping axels in my 87 plow blazer. I have a set of 3/4 ton axels with 3.73 gears. The rears is a semi floater. I need to keep e-brake working. stick truck. What ebrake cables work with the sf axels into blazer??
I believe you should be able to use your old e-brake cable on the new 14 bolt SF. I put that same axle in my sub. and the cables switched right over. What year is the 14 bolt axle you have? /forums/images/graemlins/burb.gif
