I did this once, and I cased it on a rock and tore those suckers right through the frame. If you do use this method, you should weld in some steel to make it more solid.Tabb89k5 said:One thing you might want to do after the lift is move the spacers on the t-case brace from the bottom to in between the frame and brace. It will help reduce the angle on your drive line. Before I did this, I was going through rear U joints every 3-4 years when it was my DD. I've had no u joint problems since then.
DONT DO THAT! as mentioned, you will break the frame as they pull through!Tabb89k5 said:One thing you might want to do after the lift is move the spacers on the t-case brace from the bottom to in between the frame and brace. It will help reduce the angle on your drive line. Before I did this, I was going through rear U joints every 3-4 years when it was my DD. I've had no u joint problems since then.
