Here is the Rundown,
1990 Chevy Blazer 350 w/Edelbrock Multiport fuel Injection 700r4, transfer case is an np241c 9" shackle flip lift on 37's. Motor was just replaced with a long block and only has 500 miles on it and Includes a 5yr 50k mile warranty. Transmission was rebuilt in 03. The stock 10 bolt rear end blew up last year so instead of replacing it I found a 14 bolt out of a 3/4 ton, went through that replaced all bearings, brake shoes and had the drums turned 4.88 gears along with an Auburn posi carrier installed, also went through the front end with new 4.88 gears and Auburn Posi carrier and warn premium hubs. I also went through the transfer case and installed a slip yoke eliminator from jb conversions, new rear driveline and replaced the u-joints on the front one. It has cross over steering with a High steer arm (shown in the pics) also has steering box support which is basically 1/4 steel plate welded to the frame. rancho 5000's all the way around dual shocks up front steel braided brake lines Ps pump, Windshield, rear window motor, heater core, blower motor has all been replaced within the last couple years. A/c works and blows cold that’s about it for the drive train. On the inside I replaced the carpet when I got it which was about 5 years ago it’s still in pretty good shape it has an alpine deck 2 jL audio amps that run 2-6"x9" and 2 1" tweeters, Subs are 2-12" in a sealed box it also has Sirus built into the deck. 2 TVs in the visors haven’t got around to hooking up the DVD player yet but I have it sitting in my garage. It has an alarm with push button lock and unlock. I had it repainted 2 years ago using the stock colors. Headliner recovered along with the visors they look like new. Some bad things horn doesn’t work, cruise doesn’t work, driver seat foam bottom cushion worn, I have a lot of money invested into this rig and hate to sell it, but its time to move on to other projects.
Asking 9,000 obo located in Sacramento Ca, Just passed CA smog on 1/7/11
Phone #916-370-4622
Pics, paste the link minus the star, this is my first post so I'm not allowed to post URL's yet. maybe another member can repost the pics in the thread Thanks> http*://share.shutterfly.com/action/welcome?sid=1AYsWzhk0bsmEb&emid=shareprintsharer&linkid=link5&cid=EM_sharshar
Phone #916-370-4622
