I have a 90 k5 tbi 350. It has been running good. I re timed it and made sure everything was good. I advanced it 2*. It had a hiccup off the line but ran strong and smooth through the rest of the power band.
I live at the top of a hill. Coming home Saturday night, I turned up my street and the motor sort of backfired/ hickup'd and then started running like ****. I feathered the throttle to get it up the hill and as soon as I let off at the top it died. I coasted up to the curb next to my house and just left it be and went inside. I came out the next day and started it up. drove it into the driveway but it was running and idling rough.
I unplugged the timing wire and checked the timing. it wasn't even close. Off like 40*+. I checked TDC and made sure the distributer was still stabbed correctly. I can time in with the timing wire disconnected and runs good. Turn the motor off and plug the timing wire it and it runs like **** again timing jumps all over and just wont smooth out. vacuum lines are all connected and cant find any vacuum leaks.
Any ideas are appreciated and I've searched but I can't find anything similar but there's lots of other info out there. Thanks in advance.
I successfully made my beach trip in the blazer. I got the K5 running Thursday night and was able to hit the road Friday after work. I ended up replacing the distributor with a local junk yard one. It looked a little dirty but I cleaned it up, put my electronics on it and went from there. I had a few issues with timing it because I drop my timing light and it decided to no longer time things correctly. I didn't know this at first but had a hunch because it wasn't timing right off the light. The timing mark wasn't even near the timing marks. I barrowed one from a friend down the road and boom! She liked me again. The last issue I now have to deal with is there is a substantial stutter/ power drop on take off. When hitting the throttle on acceleration, it pops/stutters and then comes on strong and smooth through the rest of the rpm's. It has an old tbi spacer and I'm going to start by removing that and see what happens. Any advice?
